09-06-2013 07:56 PM
Hi guys,
In Multisim, we can plot various kinds of graphs, which again can be export to data files like *.csv. I have a csv file, which contains data in X and Y axes. How can I import this data file into Multisim, and make it displayed in a graph?
Thanks in advance.
09-09-2013 02:41 PM
The Piecewise linear source (PWL) accepts data as voltage or current vs. time. You can find this part by selecting Place>>Component, go to the "Sources" group then select "Signal voltage sources". Place this part on the work area, double-click on it and there should be an option to open a .txt file.
04-02-2014 10:11 AM
Hello sir
have you been abled to import data file with .csv extension tn to the multisim means in signal form as Tien P. guided you????
if yes then how????
waiting for your kind reply.
thanks
04-02-2014 02:07 PM
You can use software like Excel to open the .csv file and then save the data as .txt file.
06-25-2018 03:29 PM
How should be the format of the .txt file?
Canberk
