03-12-2021 09:52 PM
Where can I get help with a circuit I created? Currently it is not functioning the way I need and I have to add a 4 position rotate switch, as well as a sound.
03-13-2021 09:59 AM
Right here in this forum.
03-13-2021 06:33 PM
The purpose of this circuit is that it acts as a dice rolled for a board game. The 14 LEDs will choose a random number as you hold the push button(S1) down. I need to add in a reset switch and a four position rotator switch in. Once and awhile this circuit will work other times I will receive the second picture error.
03-13-2021 08:52 PM
Well all LEDs light up however they are duplicate as the others are i am wondering if i need a second 4017.
03-15-2021 06:49 PM
Hi Adam81986,
I don't have Multisim so I cannot open the circuit from your latest post. From the image(s) in your previous post, however, I think these are errors in the right "die":
Well all LEDs light up however they are duplicate as the others are ...
If you connect the corresponding LEDs of the left and right dice in parallel, there's no surprise "they are duplicate as the others are."
... i am wondering if i need a second 4017.
There are many ways of creating the circuit, you can try the two-4017 approach to the design problem.
G. Goodwin
03-15-2021 07:12 PM
I appreaciate the help I caught those first errors you mentioned and realized that they are in parallel, it has been two days of trail and error to figure out how to get the second 'die' to act on its own. I added a 4017 IC and had it try to wire the to match the first one without adding a second 555. However it only gives power to the LEDs and does not rotate the LEDs through.
03-15-2021 07:24 PM
I may have figured it out however can you explain what the bottom photo means? That keeps coming up
03-15-2021 11:39 PM
Regarding this Simulation Error message, I took a detailed look at your circuit but I think I cannot render further help about this especially since I don't have Multisim. In Multisim Live, as a Free Subscription user, I don't have access to sequential devices. Besides, the (CD)4017 might not be available as of this time even to Premium account users. You should try to clear this error message first before putting additional functions/components. Here are my recommendations:
03-15-2021 11:45 PM
Also, click the Yes button in that dialog box to run Convergence Assistant.
03-17-2021 07:27 PM
I have slowly started to remove wires and items but when i run the convergence assistant it says it cannot reproduce the problem.
