When simulating circuits in Multisim 2001 with op amps from User library am getting Netlist Error message "Unable to correctly determine the nodes for the current circuit due to the following reasons:
Too many parameters for subcircuit type lf156_op_amps_1 (instance: xxu3)"
or a similar message for whatever op amp am using. Have tried creating components for several different op amps and always get same error message. Carefully checked the Pin Mapping Table and the symbol pins are correctly matched with order of pins in model. The only way have been able to get a simulation to run with op amp components in the User Library is if copy an op amp directly from Multisim library to User library and make no changes whatsoever. But if do something seemingly minor such as bring up the Symbol editor and add a text note underneath the symbol then get the "too many parameters for subcircuit" error.
Am also getting a Consistency Self Check error stating "Error: The circuit it empty. Simulation requires at least one ground." Do have ground in circuit; presumably this error is related to Netlist error above.
Operating system is Windows XP Professional.
