03-23-2007 04:08 AM - edited 03-23-2007 04:08 AM
Message Edited by chuckyRose on 03-23-2007 04:10 AM
03-23-2007 06:45 AM
04-06-2007 08:07 AM
I was surprised that suppling an initial condition of 100 volts on an electrolytic cap resulted in a negative voltage at the positive terminal with the negative terminal connected to ground.
This seems a bit counter intuitive, and if a smaller voltage was set in a complex circuit, I think I could loose some time trying to find this.
Any opinion?
Jim
04-10-2007 06:48 AM
Jim,
you are right, I have the same behaviour with electrolytic caps (not with regular caps though) on my installation. I'll report this to our support team.
As there is no report, that lists all initial conditions for parts in a given circuit (I'll file this as a feature request), I came up with this workaround:
Export the circuit as a netlist (menu Transfer > Export Netlist) and search the expoprted text file for "IC=".
