Multisim and Ultiboard
Move relative
Hello Guys,
Does Ultiboard have move relative command (similar to '*' key) which moves the component from it's actual position by given distance = relative to absolute coordinates?
Jirkus
(7,047 Views)
Hi Jirkus,
The best way to do this is to double-click the part to open its properties and navigate to the Position tab. From there you can do a quick calculation based on how far you want to move the component and assign an new absolute X and Y value.
Let me know if that helps.
Jeff
(6,980 Views)
Thank you, it seems that there is no other solution but edit absolute coordinates. I was looking for the same functionality as Menthor Graphics Pads does. There you click the part, type srx 30 and the part is moved relatively 30 mils to the right.
(6,965 Views)
Unfortunately that feature is not included. However I'd encouage you to post it in the Idea Exchange and see if others agree!
Cheers!
(6,960 Views)
Added to Exchange.
(6,958 Views)
