Multisim and Ultiboard
Move a track past a PTH or via
Hi All.
How to move a track past a PTH or via.
This is what I mean.
For example, you have a 2 row connector, and a track passes between the 2 rows. You need to move this track out from between the 2 rows to rearrange the tracking, Ultiboard will not let you. You have to delete the track (as far as I can see) and re-track around, the same applies if you want to move past a via, you can't.
Surely there is a way other than re-tracking!
If this is to do with the DRC, why can't there be a simple ON/OFF for DRC?
Russ
Message 1 of 1
(2,535 Views)
