12-13-2020 12:18 PM
I've constructed a bridge rectifier with a capacitor. Is there a way in Multisim to measure ripple voltage?
12-15-2020 06:08 AM
Hi villabacho,
You can use the cursors to measure the characteristics of ripple.
The image below is a Bridge Type Full-Wave Rectifier circuit and the Configuration Pane showing the simulation settings.
The next image below shows the Grapher Window and how cursors are used for measuring the ripple voltage after a Transient Simulation run. Cursor C2 measures the maximum voltage at the output while C1 measures the minimum. The measured values are at the bottom of the window, ΔY is the difference between C2 and C1.
Although I used Multisim Live for this, cursors are also available in Multisim (Desktop) application.
G. Goodwin
12-15-2020 01:15 PM
Great, that was what I was looking for. Thank you.
