02-15-2018 06:13 AM
In a simululation I found an Error while using 7812 regulator. I tried to simulate a power supply with 230VAC without transformer. I need only 10mA at the output.
After the simulation I tried to build up tis circuit in real and found out, that it doesnt work properly. I got not more than 3 Volts out of it.
Then I simulated the 7812 for itself and I found an error. It delivers under all circumstances 12.xx Volts even without a power source. I tried the other ones and found out that 7805 was working properly, all the others hat te same mistake.
Am I wrong or is there a malfunction in the models? I am usinf the students version 13.0
Regards
HorstHühn
04-11-2018 09:43 AM
Yes, it looks like incorrect behavior. Thank you for pointing it out!
09-26-2022 04:38 PM
Yes, I noticed the same problem when trying to simulate a power supply. The 7805 regulator is the only one in the 78xx family that works like the real circuit. All others have a mysterious voltage at the input when disconnected, so the output never goes to zero. I attached a Multisim simulation to illustrate the issue. I added pull-down resistors on all the inputs but they made no difference.
09-27-2022 01:14 AM
"После моделирования я попытался создать эту схему в реальном режиме и обнаружил, что она не работает должным образом."
Входное напряжение стабилизатора не более 35 вольт, а вы подсунули 220!
Он вообще должен сгореть, или пробиться.
