06-17-2007 09:25 AM
06-18-2007 09:49 AM
06-18-2007 07:28 PM
This device is a voltage-controlled switch.
To change the component’s parameters:
Switches are interactive components that can be closed or opened (turned on or off) by pressing a key on the keyboard, or by using the mouse.
To specify the key that controls the switch:
To toggle the switch on or off using the keyboard, press the identified key.
To toggle the switch on or off using the mouse, hover the cursor over the switch’s arm and click when the arm takes on a thickened appearance.
A small number of switches, for example, time delayed switches, current controlled switches and voltage controlled switches are not interactive components. For these components, the contents of the Value tab will be different than those described above, and will vary depending on the selected component.
Change the settings for these devices in the usual manner; double-click on the component, select the Value tab, and enter the desired parameters.
06-19-2007 08:15 AM
