Multisim and Ultiboard
MS13. Bus Entry Connection window
Hello everybody.
there is my question\ suggestion -  I am using MS 13 - and have to use a lot of bus connections in my design.
when I do connect wire to bus , MS opens for bus entry connection window.
so far so good.
but some how I can see only 6 top lines in that window directly and the rest with scrolling down.
the window could be re sized to show more \all lines, but after I click OK button and have to open that window again - it again appears with 6 top lines shown - it means that window does not remember it was re sized a moment ago.
and it becoming really annoying if I have to connect a lot of wires to the bus.
bus vector connection window does remember resizing instead .
the problem is I can not use vector connections for separate wires (not IC leads)
could it be reconfigured?
could it be fixed in next version please?
thanks a lot
Michael
(3,650 Views)
Hello aa232004,
I have researched and made some tests on my side and Multisim doesn't seem to include this feature/configuration yet. I can mention this as an idea for the future, but the best way you can make this feedback get to R&D would be through the ''Ideas Exchange'' page, so I encourage you to post this same message in there so it can be heard by the right group.
"Additional NI Software Idea Exchang"
http://forums.ni.com/t5/Additional-NI-Software-Idea/idb-p/nisoftware
Thank you for pointing this, it is very useful for improving our products in the future.
Best regards!
Daniel C.
(3,633 Views)
