05-11-2007 08:29 AM - edited 05-11-2007 08:29 AM
Message Edited by hala_oi on 05-11-2007 08:31 AM
Message Edited by hala_oi on 05-11-2007 08:45 AM
05-15-2007 11:25 AM
You should ignore this error message you will always it when simulating an MCU. The problem is due to a third part character size limit if we allow the MCU to write temporary files to C:\Program files…. we can not guarantee the temporary file name will exceed the character limit so to work around this, MCU write the files to a dummy network drive.
However, if you got a real error message, you should attach your schematic instead as well as the code file.
Tien
05-30-2007 08:21 PM
05-31-2007 09:39 AM - edited 05-31-2007 09:39 AM
Hi CheValier,
I just found out that the MCU compiler does not simulate on
D:\National.Instruments.Circuit.Design.Suite.v10.0.Power.Pro\interrupt\interrupt\interrupt\act3\ has been mapped to the drive Z: temporarily for this operation.
Error: Unable to run assembler.
I know that R&D have fixed this issue and will likely be available in future release.
Tien
Message Edited by Tien P on 05-31-2007 10:01 AM
05-31-2007 12:39 PM
