Multisim and Ultiboard
Looking for MC1496 - any custom part library?
Please try the attached spice model, if working pl tell me also
Message 11 of 27
(2,339 Views)
Message 12 of 27
(2,338 Views)
I'm trying to understand this 'dance of the pins'.  Are you saying that although the subcircuit lists the pins as 1 2 3 4 5 6 8 10 12 14, as far as the model is concernted the pins are 1 2 3 4 5 6 7 8 9 10?
Thanks...Steve
Kaman Precision Products
Message 13 of 27
(2,335 Views)
Okay, replying to my own message.  Yes, as I stated, that is the case, so pin 7 of the model (subckt pin 😎 must be routed to pin 8 of the symbol.  Now my model works.
Message 14 of 27
(2,330 Views)
If your circuit is working with 1496, please send me its file so that i can run it on multisim also ! dr_parjit@hotmail.com
Message 15 of 27
(2,301 Views)
My circuit for Amplitude modulation with 1496 is not working. I am unable to attach this file because its extension is in ms12 (not valid), so if u send me your e-mail then i can try dr_parjit@hotmail.com
Message 16 of 27
(2,277 Views)
I'm not sure what you are looking for.  As far as I know, I can't export a working part to send to you to import into Multisim.  You have to go into Component Wizard and create the footprint, then you can copy/paste the model.  On this board, there is a model for the LM1496, which is the same chip as the MC1496, just a different manufacturer, however, you do have to do the work in component manager to get the part into Multisim.  I don't know of any other way, unless someone else knows....
Message 17 of 27
(2,276 Views)
Hi didymus7,
If you have a working part, you can place it on a schematic and post it. Someone who views the schematic can right-click and select Add Selection to DB.
Hope this helps.
Tayyab R,
National Instruments.
Message 18 of 27
(2,258 Views)
I have tried to zip the required please download and unzip and check!
Message 19 of 27
(2,245 Views)
hey i have the same circuit & i've falloed all etapes but still doesn't work can u tell me how exactly did u add the MC1496 To multisim plz
Message 20 of 27
(2,230 Views)
