03-05-2012 03:09 AM
Please try the attached spice model, if working pl tell me also
03-05-2012 03:10 AM
dr_parjit@hotmail.com
03-05-2012 09:21 AM
I'm trying to understand this 'dance of the pins'. Are you saying that although the subcircuit lists the pins as 1 2 3 4 5 6 8 10 12 14, as far as the model is concernted the pins are 1 2 3 4 5 6 7 8 9 10?
Thanks...Steve
Kaman Precision Products
03-05-2012 12:51 PM
Okay, replying to my own message. Yes, as I stated, that is the case, so pin 7 of the model (subckt pin 😎 must be routed to pin 8 of the symbol. Now my model works.
03-26-2012 12:28 AM
If your circuit is working with 1496, please send me its file so that i can run it on multisim also ! dr_parjit@hotmail.com
03-28-2012 05:27 AM
My circuit for Amplitude modulation with 1496 is not working. I am unable to attach this file because its extension is in ms12 (not valid), so if u send me your e-mail then i can try dr_parjit@hotmail.com
03-28-2012 07:39 AM
I'm not sure what you are looking for. As far as I know, I can't export a working part to send to you to import into Multisim. You have to go into Component Wizard and create the footprint, then you can copy/paste the model. On this board, there is a model for the LM1496, which is the same chip as the MC1496, just a different manufacturer, however, you do have to do the work in component manager to get the part into Multisim. I don't know of any other way, unless someone else knows....
03-30-2012 09:52 AM
Hi didymus7,
If you have a working part, you can place it on a schematic and post it. Someone who views the schematic can right-click and select Add Selection to DB.
Hope this helps.
04-02-2012 04:33 AM
I have tried to zip the required please download and unzip and check!
04-13-2012 08:12 AM
hey i have the same circuit & i've falloed all etapes but still doesn't work can u tell me how exactly did u add the MC1496 To multisim plz
