02-17-2009 04:05 PM
Hello.. I'm trying to make a labview Input/Output instrument that will take an input, compare the input against a lookup table (preferably in a text file), and output the value that was looked up. I've been playing with the example labview IO template project that came with Multisim, and I am having trouble figuring out how it works. Can someone make an example that would, say, take the input, multiply it by two, and output that value just so I can see where in the block diagram the calculation is supposed to be done?
Thanks!
Mike
02-19-2009 10:35 AM
Hi Mike,
Here is a good tutorial on how to create LabVIEW Instruments for Multisim:
How to Create a LabVIEW Based Virtual Instrument for NI Multisim
Let us know if you have further questions.
02-19-2009 11:26 AM
Fernando,
Thanks, that is a good tutorial.
Can you try building the example project and see if it shows up in Multisim?
I can't get any of the example projects to show up in Multisim.. I can get the pre-built .llbs to show up but when I try to build anything it doesn't work. I noticed that the pre-built .llbs are ~150kB and when I build it's ~87kB. Any idea what's going on?
Mike
02-19-2009 01:55 PM
Mike,
What are your software versions? Depending on this you might need some additional files to assure the compatibility between LabVIEW and Multisim. Click here for more info.
Please let me know how it works.
