09-22-2017 11:49 AM
Hello!
I used four Opamps of a single LM324N in my circuit, but when I transfered to ultiboard, my layout was created as if I were using one opamp of four different LM324N's. I really need a layout with a single LM324!
Somebody help me, please!
09-26-2017 02:53 PM
Hello Wesley
I'm going to show the procedure to add 4 OpAmps of the same chip in Multisim, please let me know if it is how you are doing.
- Search for the component you want to use (figure 1);
- Click OK;
- Select the A button (figure 2). Doing that you're selecting to use the OpAmp A of a new chip;
- From there on, you can keep adding more OpAmps of the same chip clicking on the buttoms U1 - B, C or D (figure 3).
Every time you select a component that is already on the schematic, you will be asked to choose if you want to use a existent chip or a new one.
PS. You can change later the sub component you want to use on the component property (figure 4).
Please let me know if the issue persist.
09-27-2017 06:19 PM
Thank you!
09-29-2017 07:49 AM - edited 09-29-2017 07:50 AM
