ni.com is currently experiencing issues with downloads. Support teams are actively working on the resolution.
Multisim and Ultiboard
Indicators Flash when using AC sourch
While using multisim and building a simple circuit.  Momentary push button on, relay with n/o outputs, and using an AC source, the coil on the relay flashes and the light bulb flashes.  I have another light bulb just connected directly to the source it flashes.  I understand and have found things on the forum about the wave actually is turning on and off and I understand this, however, you should not be able to see this and it should not be energizing and de-energizing a coil relay or making the bulb flash where you can see it.  Is there a way to make this stop?  Please help as I am new to this and can't seem to find a solution in the forums, outside of just making my circuit DC, which is not what I want to do.  Thanks in advance.
(2,464 Views)
Hi jlcarlisle,
It would be very helpful if you share the code so members can review it and provide recommendations.
Best regards.
(2,433 Views)
