01-04-2022 05:05 PM
I am new to multisim and I would like to ask for help because I am still learning how to make my own spice models. I am trying to import into multism a spice model of FDS4559 N channel mosfet. The source text of the model is given at the bottom of the post and it is downloaded from https://www.onsemi.com/PowerSolutions/supportDoc.do
I am trying to understand the mistake I made while importing. In the component wizard I did the following steps:
Can somebody please tell me where I went wrong? Thank you for your time. Source text:
*FDS4559 at Temp. Electrical Model (Complementary N-Ch)
.SUBCKT FDS4559CN 20 10 30 50
*20=DRAIN 10=GATE 30=SOURCE 50=VTEMP
Rg 10 11x 1
Rdu 12x 1 1u
M1 2 1 4x 4x DMOS L=1u W=1u
.MODEL DMOS NMOS(VTO=2.8 KP=31.8
+THETA=0.066666667 VMAX=1E5 LEVEL=3)
Cgs 1 5x 636p
Rd 20 4 1.65E-2
Dds 5x 4 DDS
.MODEL DDS D(M=4.95E-1 VJ=9.25E-1 CJO=278p)
Dbody 5x 20 DBODY
.MODEL DBODY D(IS=2.88296E-11 N=1.1999639 RS=0.00063995 TT=23.74n)
Ra 4 2 1.65E-2
Rs 5x 5 0.5m
Ls 5 30 0.5n
M2 1 8 6 6 INTER
E2 8 6 4 1 2
.MODEL INTER NMOS(VTO=0 KP=10 LEVEL=1)
Cgdmax 7 4 459p
Rcgd 7 4 10meg
Dgd 6 4 DGD
Rdgd 6 4 10meg
.MODEL DGD D(M=3.52E-1 VJ=1.56E-2 CJO=459p)
M3 7 9 1 1 INTER
E3 9 1 4 1 -2
*ZX SECTION
EOUT 4x 6x poly(2) (1x,0) (3x,0) 0 0 0 0 1
FCOPY 0 3x VSENSE 1
RIN 1x 0 1G
VSENSE 6x 5x 0
RREF 3x 0 10m
*TEMP SECTION
ED 101 0 VALUE {V(50,100)}
VAMB 100 0 25
EKP 1x 0 101 0 .031
*VTO TEMP SECTION
EVTO 102 0 101 0 .0035
EVT 12x 11x 102 0 1
*DIODE THEMO BREAKDOWN SECTION
EBL VB1 VB2 101 0 .08
VBLK VB2 0 60
D 20 DB1 DBLK
.MODEL DBLK D(IS=1E-14 CJO=.1p RS=.1)
EDB DB1 0 VB1 0 1
.ENDS FDS4559CN
Solved! Go to Solution.
01-09-2022 05:00 AM - edited 01-09-2022 05:10 AM
Привет!
Для комплиментарных пар в Мультисим есть другие модели, а эта, похоже, для температурной, 4-выводной модели, для одного N-MOS
...-и моя попытка создать индивидуальный компонент тоже не привела к успеху, ошибка, думаю в неправильном назначении выводов, или вообще удалить лишний, - тогда на характериографе получим 2 кривые
А через SPICE-блок, вроде, всё правильно симулируется...
01-10-2022 01:26 AM
Thank you very much tipa!
01-10-2022 02:48 AM
-а где похвала?!,- любезнейший...
01-11-2022 12:17 AM
Спасибо, дорогой!
Я звёзды с неба не ловлю, мне-б дали просто, хоть одну...
