Multisim and Ultiboard
I cannot open my multisim 2001.
A message box appears and inside is a forward slash ( \ ).
The splash screen appears behind the message box and goes through LOADSDLL(with a bunch of targets or whatever cycleing through)?
The only thing I did recently was uninstall the freeware edition of Multisim 9 with EWB shared components.  Could this be the problem and if so why is it linked
with multisim 2001?  Please help.  I am a student and even multisim 2001 I got for 15 bucks helps out a lot.
(5,358 Views)
The freeware version should not have affected the Multisim 2001 as they are independent of each other.  When you startup Multisim and get a dll error messages, this is usually an indication of an install problem. I would try to reinstall the program.
Make sure you clean up your machine before you do this.
  1. Remove Multisim through the add/remove program utility from your control panel
  2. delete the Multisim install folder
  3. reinstall Multisim
(5,339 Views)
