A message box appears and inside is a forward slash ( \ ).
The splash screen appears behind the message box and goes through LOADSDLL(with a bunch of targets or whatever cycleing through)?
The only thing I did recently was uninstall the freeware edition of Multisim 9 with EWB shared components. Could this be the problem and if so why is it linked
with multisim 2001? Please help. I am a student and even multisim 2001 I got for 15 bucks helps out a lot.
The freeware version should not have affected the Multisim
2001 as they are independent of each other.When you startup Multisim and get a dll error messages, this is usually an
indication of an install problem. I would try to reinstall the program.
Make sure you clean up your machine before you do this.
Remove
Multisim through the add/remove program utility from your control panel
