10-10-2008 11:28 AM
Hi... well Im trying to build a circuit and I need the LM317 to create it, i can´t find it anywhere in the internet... could someone please help me out?, i have the multisim version 10....
I´ve seen some codes but I don´t know where to put them....
Any help would be appreciated...
Eugenio
10-10-2008 02:39 PM - edited 10-10-2008 02:39 PM
10-10-2008 09:29 PM
thanks for the quick answer!
I´ve tried again, "master database" "all groups" "all families" and the only results i get when i type LM are timers (like the 555), but not the LM317... I would appreciate your help....
Thanks!
10-12-2008 08:36 AM
The problem may be that your verison does not have them. I have the Power Pro edition and they are in POWER>Voltage Regualtor. I trie a search for them and that wored great on mine. So this tell me that you may notm have them.
I am going to post one from my database for you. You may be able to save this to your database depending if your version supports that function. If not, then you can still use it by copying and pasting it into your circuit.
Here it is:
10-12-2008 02:50 PM
thank you very much lacey
worked great this time
thanks!
12-21-2009 05:59 AM
I need it too,thank you!
12-31-2011 12:57 PM
Thank you! I needed the LM 317 as well and I was able to use the file from your post.
01-01-2012 10:31 PM
Also try LM117 its the same part for military
11-13-2016 09:18 PM
HOLA NO ENCUENTRO EL COMPONETE,: LM317AH ESPERO QUE ME AYUDEN. O COMO LO DESCARGO TENGO LA VERSION 13 MULTISIM
gugo8940 escribió:Hi... well Im trying to build a circuit and I need the LM317 to create it, i can´t find it anywhere in the internet... could someone please help me out?, i have the multisim version 10....
Eugenio
11-14-2016 07:32 PM
Mira la solución arriba, puedes descargarlo del link que pusieron
