Multisim and Ultiboard
How to setp up LED red to 1.8V and blue with 2.7V?
here I have an image which explains the reason for this thread.
https://imgur.com/a/5JgXHfS
From a video, it was showed that in the following circuit only red LED glows:
9V battery, 3.9K Ohm resistor, 2 LEDs blue (2.7V) red (1.8V).
I build the circuit and both LED are emitting light.
https://i.imgur.com/eCUGlp4.png
Thank you.
(2,021 Views)
No one has an idea? Or is my question to beginner like?
(1,967 Views)
Accepted by topic author xan137
The LEDs color selection is not related to the corresponding voltage that the LED needs for a proper functionality (is more like a matter of aesthetics).
This is not implemented in its model.
You can use the Ion parameter to adjust the voltage across LEDs, using a series resistor with them.
However, this is not the best approach, since for a VD voltage of 0.6V, the LED easily opens, behaving like a regular diode, and not an LED.
This issue is taken into account and transmitted further, with the hope another component will be added in the future.
Thank you for your input on this matter.
Monica Ignat
(1,935 Views)
Why does the LED closes already with 0.6V? This makes no sense.
(1,609 Views)
В модели диода настройте ток поджига так, чтобы падение н
апряжения соответствовало вашему желанию
В варианте с произвольным спайс блоком нужно подобрать ток IS в модели, взятой из спайс нет листинга
Поскольку в синем лэде получался слишком маленький ток, я взял модель красного светодиода и подставил в синий, отрегулировав IS под нужное напряжение(можно было ещё чуть чуть увеличить, чтобы ровно 2,7 вольт получить)
(1,594 Views)
I'm using the live Multisim, https://www.multisim.com/create/, the one running in the browser.
(1,539 Views)
Возьмите модели из 14 версмии и перенесите в live
(1,535 Views)
