01-25-2007 12:05 PM
01-25-2007 12:20 PM
01-25-2007 12:26 PM
01-25-2007 12:50 PM
I know that changed for virtual mosfets, here is the way you can workaround it, place the virtual mosfet alone on the schematic, then go to Transfer >> Export Netlist... you will now have a text file with the full model you used to find in version 7. You can use this model to create a new component with the wizard like you said. Or use one of the components from the database, like the one I mentioned, and Edit it so you can save a new component with the new model in your user database, and pass this component to your students. The final model should be something like this
.subckt 12343 1 2 3
m1 1 2 3 IDEAL w=100 l =100
.MODEL IDEAL PMOS (
+ LEVEL= 1
+ VTO= 0.0
+ KP= 2.0e-5
+ GAMMA= 0.0
+ PHI= 0.6
+ LAMBDA= 0.0
+ RS= 0.0
+ RD= 0.0
+ CBD= 0.0
+ CBS= 0.0
+ IS= 1.0e-14
+ PB= 0.8
+ CGSO= 0.0
+ CGDO= 0.0
+ CGBO= 0.0
+ RSH= 0.0
+ CJ= 0.0
+ MJ= 0.5
+ CJSW= 0.0
+ MJSW= 0.5
+ JS= 0.0
+ TOX= 1.0e-7
+ NSS= 0.0
+ TPG= 1.0
+ LD= 0.0
+ UO= 600.0
+ KF= 0.0
+ AF= 1.0
+ FC= 0.5
+ TNOM= 27
.ends
I hope that helps...
02-13-2007 03:29 PM
