your I1 current source is wrong. Instead of having an independent 5A source you should use a current controlled current source that copies the current flowing through R2 (i_beta), multiplies it by 5 and injects the result (5i_beta) into the node between R1 and R3 (see below).
Other than this detail your circuit seems correct.
