07-09-2008 02:30 AM
07-09-2008 08:27 AM
07-09-2008 08:53 AM
07-09-2008 12:05 PM
07-09-2008 12:11 PM
07-09-2008 01:11 PM - edited 07-09-2008 01:14 PM
07-11-2008 03:56 AM
AFAICT the approach of using a "keep out" works when you know in advance of placing the power plane that you want to make a hole in it, and where.
All that seems to happen if you place a keep out after the event is that you get a DRC telling you that the keep out has stuff in it that shouldn't be there.
So the track and delete island seems the way to go.
Unless of course ...
Cheers, Dave
07-11-2008 06:04 AM
Hi Dave,
why dont you use the poligon splitter option of UB. You can splitt the plane and delete the unneeded part of the plane.
Greetings from germany
GP
07-11-2008 08:28 AM
07-11-2008 09:01 AM
Dave,
I've confirmed that Garret's method works wonderfully, and is less complicated than the trace and remove island method. The main thing is that the keep-out layer will make the power plane not draw there, but will not remove anything else. 🙂
