Multisim and Ultiboard
How do I create a dependant source?
Hi, I'm new to Multisim, and I was wondering how to create a dependant source.  For example, if the voltage drop on a resistor is designated as V_x, and I wanted a dependant voltage source whose value was 2*V_x.
(2,883 Views)
Hi Doven,
Yes, you can definitely do that with Multisim. Please navigate to Place->Component->Master Database->Sources->Controlled voltage sources->Voltage_controlled_voltage Sources. That component should enable you to build a dependent voltage source.
Derek Z.
(2,880 Views)
