Multisim and Ultiboard
How do I change a component in an existing design?
I have an existing design created in V11.0 Multisim/Ultiboard. I want to change a single component to replace a transistor in a D2PAK to a part in a DPAK.
I edited the component in my users library to use the DPAK footprint.
I transferred (Transfer to Ultiboard 11.0) the revised design to Ultiboard. All components and traces were ripped off the board and the board outline was deleted. All that is left is a board outline rectangle with lots of components scattered around it.
This happens if I transfer from Multisim to Ultiboard, or if I open the ewnet file from Ultiboard.
The documentation/help says nothing about modifying existing designs.
How do I make changes to existing boards without having to start over from scratch?
PRH
(5,894 Views)
Accepted by topic author DrPR
Don't transfer to Ultiboard - this basically creates a new design - what you want to do is forward annotate only (which will only update the design).
Optionally you can transfer the UB Netlist only and reimport from Ultiboard.
Pat N
(5,891 Views)
Thanks.
Forward annotation seems to have done the trick.
PRH
(5,886 Views)
