04-07-2021 07:02 AM
i tried to build this circuit but im not sure if its correct.
can someone please tell me if its correct or if its not
04-07-2021 09:59 AM
Hi ghada382,
I think you've built it correctly but you may want to make improvements on these aspects:
Some parameters which are relevant to the operation of the circuit might have been stipulated in the text of the problem but are not in the circuit diagram, verify BJT's β and temperature.
Of course you may want to provide a more descriptive title for your next post.
G. Goodwin
04-07-2021 10:59 AM
If you will build the actual circuit, it's more likely that you will use polarized electrolytic for 10 μF capacitors. Thus, it could be more beneficial to opt for the capacitor symbol from your reference instead of the nonpolarized symbol you are currently using.
