10-04-2007 02:16 PM
10-04-2007 03:54 PM
I am not exactly sure what you are trying to accoplish with this filter configuation, but it is working correctly. By this I mean, that with the capacitor located where it is, it will block any DC and pass only the AC component of the signal. Therefore your are only seeing the AC ripple volatage from the bridge rectifier and blocking your DC.
If your are trying to design a what is know as a PI Filter then the capacitor has to be attached from the bridge to ground folowed by a series reistor and then another capacitor tied to that and then tied to ground.
I hope this helps. If you would happen to need a pictur of the PI Filter let me know and I will try to post it.
Have A Nice Day
10-04-2007 04:48 PM
Thank you very much Lacy. Yes I think I would appreciate the picture of the PI filter. I think I would follow your suggestion to connect the capacitor to ground. What I expect to get from what I have seen in textbooks is DC voltage with ripple. The capacitor charges then discharges via the load.
The shape of the output voltage should be such that it should be approaching a straight line. What I have seen in the textbook is that it is curve at the peak of the sinusoidal input, then it becomes a straight line(slopy down), and continues that way. Later, I will then have to use a voltage regulator.
Thank you for your anticipated support.
10-04-2007 05:09 PM
O.K. Here's a picture of your circuit with the PI Filter attached to it. I just arbitrarily selected the components to use. I used low value caps so you can still see a slight ripple on it. A larger capacitor at the end of the bridge will filter this ripple almost completely out. Most circuits I have seen usually have this cap set somewhere in the 100uF-300uF range and the output capcitor in the range of 10uf-50uf range.
I can't remember the formylas for designing a PI Filter, but I am sure if you search the internet there are resources that can help you with that. I think I may refreshen my memeory on this subject as well.
Here's the picture and I hope this works for you.
10-04-2007 10:30 PM - edited 10-04-2007 10:30 PM
Message Edited by kittmaster on 10-04-2007 10:31 PM
Message Edited by kittmaster on 10-04-2007 10:35 PM
10-04-2007 10:38 PM
10-05-2007 04:39 AM
Thank you for your replies. The purpose of the capacitor is to eliminate fluctuations in the rectified voltage and produces a relatively smooth dc voltage. Based on the suggestions you guys made, I have finally come up with a schematic, that I think works for me. I am in the stage of applying a voltage regulator.
I have attached my circuit.
Thank you for any comment.
10-05-2007 08:21 AM
10-05-2007 10:07 AM
10-05-2007 10:38 AM
I have a question for Chris. I know Pi Filters may not be used as much as in the past (or maybe not at all now), but wouldn't an L/C Pi filter in power supply applications not only provide better ripple reduction and interference rejection, but wouldn't it also provide better load stabilization?. Also, in my opinion, wouldn't it also provide you with the ability to use smaller capacitors like your 200uf?
Just curious as to what you opinion may be on this. I have always designed my PSs with a Pi filter just as a precaution if nothing else.
Thanks for any information you could throw my way.
Have a Nice Day
