ni.com is currently experiencing slowness/issues due to ongoing maintenance.
Support teams are actively working on the soonest resolution.
Multisim and Ultiboard
Having Trouble Importing component using component wizard Mulstisim
I am having a lot of trouble trying to import a component using the component wizard in Multisim 8.
The part I am trying to import is the SN74LVC1GU04 inverter: link here. I got the SPICE model and accessed the datasheet from the same website.
In the component wizard under component type, I selected Digital, and for component technology used TinyLogic_5V as they did not have LVC listed.
I set the pin count to 5 and copied the symbol information from the main database.
I added three hidden pins (VCC, GND, and a NC) following the naming scheme from the datasheet
I Mapped the symbol pins to the footprint pins and loaded the simulation model from a file (I used the Behavioral SPCIE model).
I mapped the symbol pins to the model nodes
All footprint numbers were taken from the datasheet
I get the following errors when I try to simulate a simple test circuit using this part:
Errors during netlist generation
Error in C:\filepath\02.CIR.cir(197):efalse nfalse vee value = {0}
eError on line 14 in C:\filepath\02.CIR.cir: au1 $du1.i1 [ $du1.o1 $du1.vcc $du1.gnd ] sn74lvc1gu04__inverter__1
e ERROR – unable to find definition of model sn74lvc1gu04__inverter__1
eError on line 60 in C:\filepath\02.CIR.cir: m_n_em_q1:xu1.o1 $2 $5:xu1.o1 $gnd $gnd nmeout
eunable to find definition of model nmeout – default assumed
I have been able to get the test circuit I am simulating running with a different inverter.
I've called NI, and they aren't able to offer support as my version of Multisim is too old, so any help would be appreciated!
Thank you,
Austin
Message 1 of 1
(308 Views)
