06-06-2007 05:08 PM
06-12-2007 09:48 AM
Hi Junt,
Try to stop the service manually and then remove Multisim. You can do this by going to the Control PanelàAdministrator Toolsà ServicesàNational Instrument Time Synchronization and right click on this and select Stop.
Tien
06-13-2007 05:57 AM
06-14-2007 02:04 PM
I just loaded
06-15-2007 10:23 AM
06-15-2007 10:28 AM
06-15-2007 01:14 PM
Hi Koekje,
Changing it to manual from automatic doesn't work, anyway I was able to uninstall/removed it without error by going to the properties and changing the status of stopping to stop in the properties section when you right click the synchronization file in the services section. After uninstall/remove, following NI engineers e-mail instructions I re-install it again but still it shows an error " NI design suite 10.0 has stopped, A problem caused the program to stop working properly. Windows will close the program and notify you if a solution is available."
So I think I cannot run this program until a patched is made to remove the error since I updated this software. Any idea that might worth trying would be of great help. Thank you for your suggestions. Junt
06-19-2007 10:29 AM
Hi Junt,
Good news, the update is available and you can download it at:
ftp://ftp.ni.com/support/circuitdesignsuite/10.0.1/
Tien Pham
06-20-2007 02:16 AM
Hi Tien I download the Design suite 10.0.1 educational (Vista update version) as per the link you provided me and Installed the software, but stil the program don;t work. The Vista OS display the following message. "NI design suite 10.0.1 educational has stopped, A problem caused the program to stop working properly. Windows will close the program and notify you if a solution is available."
I don't know why even the Vista design suite 10.0.1 educational has been downloaded and installed, still my computer does not run the program? Please advise what will be the problem and possible solutions? Thanks.
Junt
06-27-2007 11:05 AM
Hi Junt,
Problems like are really difficult to resolve so this could be anything.
Can you do this:
You may not find anything in this folder so if you don’t see it is fine. Once you do this go ahead and remove Multisim and reinstall.
Tien Pham
