04-05-2017 07:24 PM
Is there any way to surpress the targets the gerber generator inserts into the gerber files off 3 corners? Those and the corner frames are interpreted as traces by my routing mill and Altium does not create them. Would like to surpress them from being generated if possible. Right now I am manually going in and editing the gerber files with notepad and deleting the section that draws them. If I should ever use a 5mil line for anything else I'll be screwed though!
Solved! Go to Solution.
04-07-2017 12:36 PM
Are you including the board outline that shows in the Options of Gerber RS-274X properties?
04-07-2017 12:55 PM
Does it matter? The targets are on all the layers.
04-11-2017 05:41 PM
Found it, under Global Options/PCB Design there is a check box for "Show global fiducial marks".
