i would to use a DPDT relay in a circuit (S1). Placed and wired to circuit i assigned a suitable relay package but for S1 the coil wiring are missed , So i added energizing coil (K1) and assigned coil pin with another same package used for throws. Consequently in Ultiboard i have two relay packages . One for coil connection and one for throws connection. So the answer is: How can i associate S1 and K1 pins at the the same package instead to have separate two as a image?
JJ
