Hi Prof. Anil,
You can use the FREQUENCY_TABLE_FUNCTION component from Sources/CONTROL_FUNCTION_BLOCKS family.
It allows you to create a Vout/Vinput transfer function by specifying discrete data points. You can simply paste your data points into the textbox, exactly as you have them, and select "Absolute" for the Magnitude units.
If your transfer function describes an impedance, you need to sample current and convert it to a voltage, which you can use as the input to the FREQUENCY_TABLE_FUNCTION component. That way you get current input, voltage output.
I've created a little sample using your datapoints to get you going.
Attached. Run AC analysis. The plot is the impedance since I am injecting a 1A phasor.
Let me know if this is what you're looking for.
Max
