08-23-2007 07:09 PM
08-23-2007 10:00 PM - edited 08-23-2007 10:00 PM
I have something you can try and see if that is what you are looking for. Goto Place>PowerPlane and select it. Iit will ask you for the net. In my test I just arbitrarily selected VCC and copper top. It appears to place copper area around the traces. You can give this a shot and see if that is what you are wanting.
I hope I was helpful.
Edit: Select VCC on one side of the board and ground on the other side (if it is doublesided). Looks right to me in 3D view.
Message Edited by lacy on 08-23-2007 10:09 PM
08-24-2007 10:06 PM
08-24-2007 10:31 PM - edited 08-24-2007 10:31 PM
Message Edited by kittmaster on 08-24-2007 10:37 PM
08-24-2007 10:38 PM - edited 08-24-2007 10:38 PM
Message Edited by kittmaster on 08-24-2007 10:39 PM
08-25-2007 07:57 AM
Thanks for the screenshots kittmaster. I know this works for 2 sided boards, but I have no idea what effect it could have with multiple layer. I would suggest caution in using this until its total effects can be determined. I really don't see where there could be a problem if you doing your own PCB work, but I have no idea on how this would effect the boards sent off for manufacture. I also want to thank you for the kudos you gave me on my solution, I really appreciated that.
Have a Nice Day
08-25-2007 12:13 PM
08-25-2007 01:15 PM - edited 08-25-2007 01:15 PM
On mine all the grounds are wired to the power plane on the side that I chose to use as my ground plane I can tell by the little "X" looking mark on the pin hole in 3D view and also on the board view. The way I see this is that if you choose one side as the ground plane then it has no effect on the other side of the board. This may be what you are seeing. It may be necessary (and I would have to find out how to do this) is to have all your grounds on one side of the board (if possible) and all the VCC on the other side. This would ensure that the pins get put into the power plane. I don't know if this is feasible, but I'll give it a shot and see.
I will continue looking at this and let you know what I can figure out. In the meantime, if kittmaster has anything to add I would be all ears.
Edit: It works. If you goto your spreadsheet and select the VCC and GND net you can force it to either top or bottom. Then re-route your board. Place your power plane. Then look at the board view and 3D view and you will notiice that some pins appear to have a little "X" on them. This indicates they are connected to the plane.
Message Edited by lacy on 08-25-2007 01:27 PM
08-25-2007 01:52 PM - edited 08-25-2007 01:52 PM
Message Edited by kittmaster on 08-25-2007 01:52 PM
08-25-2007 02:57 PM
That's cool to know kitmaster. I didn't know you could select the same net for both sides as I never tried that. But he could still cut down on his etching using my method of basically eliminating 2 nets VCC and GND and putting these on the planes top and bottom if that is what he wanted to do.
To be absolutlely clear on this. If a person wants one particular net on both sides of the board to be attached to a plane, then you must select the same net for both sides( on a double sided board of course). This would apply to any net you choose. You can also have split power planes with one net on one side with pins attached to its plane and another net on the other side with pins attached to its plane. I will asume this statement to be correct until proven otherwise.
I am sure ther are other uses for the power plane other than what we have been discussing. So if anyone reads this we have discovered one use for it t and is not necessarily the only way to use it.
