Verify the paths in ultiboard are correct.
In ultiboard go to options, preferences, paths and verify the directories.
Also verify that you are an administrator or have user permissions to write to the ewb directory.
If all else fails, close Ultiboard and delete the configuration files in X:\Program Files\Electronics Workbench\Ultiboard 7\Ultiboard Users >>>>>>> .ewcfg file extensions. (That should be the right path, if not do a search for the .ewcfg extension in the ultiboard directory)
Launch Ultiboard and it will rebuild these files from scratch.
If that don't work, uninstall the Ultiboard complete and reinstall (saving all your files in those directories if they exist)
Chris
Message Edited by kittmaster on 07-15-2006 01:52 PM
Message Edited by kittmaster on 07-15-2006 01:54 PM
