09-04-2007 04:38 AM
09-04-2007 11:23 AM
09-10-2007 02:37 PM
Roman,
This is generated when the license files are not properly installed or they have been deleted. You can try to repair the installation and/or re-install the software from the original CD, or if you downloaded the evaluation, make sure you have unzip the files in your local disk (C:).
Individual license files should be installed when you repair, on any case, you can find the specific license to use depending on the Edition you have in here:
ftp://ftp.ni.com/support/circuitdesignsuite/licenses/10.0
And they should go in here:
C:\Program Files\National Instruments\Shared\License Manager\Licenses
