ACCORDING with lack of models 3, 4, 5 winding transformers library files sending me, I try once again to make up myself non-linear transformer multiple winding.
Here I describe my attempt pass through component wizard:
Step 1- (component type) - analog
Step 2- single section component, 8 pins
Step 3- (enter symbol information) – edit - I draw as I want, and may add as many pins as I want, No checking, no any tie between pins I paste in and real winding. Par example I draw 7-8 is 4-th winding but the program can’t recognized none of them
Step 4- (set pin parameters) section A, bidirectional, ERC status –include.
Step 5- (select simulation model) model maker allowed any of secondary output number!
The right way, I think, is to correct model data somewhere straight.
Step 6- (pin mapping table) only 4 nodes allowed, which exists in prototype, I can type any number I wish but in model nodes menu exist only 4 numbers + n.c.
Step 7- not important
Step 8- not important
Who knows how to work with model data? What means all this abbreviated notations? Somewhere it would be explained?
truly yours Aleks
