08-21-2007 03:29 PM
08-28-2007 01:24 PM
Hi KCT,
Thanks for your comments and suggestion. I will put your suggestion about the database search into the feature request list.
Just a note about sharing components. If you place a component on the work space and send the file to someone, when they open your file and double click on the component there should be an option to save it to their database.
If you have the Power Pro version you can also select ToolsàDatabaseàDatabase ManageràComponent, when you highlight a component or several components, click on the Export button and Multisim will create a .prz file. When the other person double clicks on this file, it will save the components to their database.
In Ultiboard, you can click on the footprint and select ToolsàDatabaseàAdd selection to database. If the board has several footprints that is not in your database, select ToolsàDatabase àDatabase Manage, on the Database column click on the + icon with the arrow pointing to the lower right, you should get a pop up with all footprint in the design file. Put a check beside the footprint you want in your database and click O.K.
