09-25-2017 04:56 PM
Are there dual gates in Multisim. For example can I swap a negative AND for an OR gate? Are there any negative gates in Multisim? Negative AND, negative XOR...
Â
Solved! Go to Solution.
09-26-2017 11:22 AM
09-26-2017 12:01 PM
Hi Pedro,
Thanks for your help but I still can not find a negative gate even in the Misc Digital area of the Master database. These are not NOR or NAND as they have inversion on the output. I am looking for negative devices that have inversion on the input. For example swapping an OR gate for its De Morgan equivalent Negative AND.
09-26-2017 02:53 PM
I understand, in that case, you'll need either to use a NOT before or create your own component following the tutorial below:
http://www.ni.com/tutorial/3173/en/
PedroR
09-27-2017 03:09 PM
Thanks again Pedro.
I have created the gates that I require.
Cheers,
10-20-2019 05:31 PM
Would you be able to share the Dual Gates you created? Is there a way to export and import them? I wanted to be able to place gates with demorgan equivalents to teach bubble-matched schematic drawing techniques. I'd love to use a library of these gates if someone has already gone to the trouble of creating them.
