Multisim and Ultiboard
Deleting power plane in ultiboard
It seems I shouldn't have to ask this question, but I created a power plane, but now I want to delete it and I can't seem to find the way to select it and delete it.  Can someone tell me how? I should mention this is my first use of ultiboard.
thanks
R
(7,894 Views)
R,
1. Check in which layer you placed the powerplane.
2. On your design toolbox select that layer to make it active.
3. Make sure that Edit >> Selection Filter >> Enable Selecting Polygons is checked.
4. Click on the powerplane to select it, then just hit your 'delete' key on the keyboard.
That should do it.
Nestor
(7,889 Views)
ah! enabling polygon, thank you - problem solved.
best,
Ryan
(7,887 Views)
