Multisim and Ultiboard
DC Power Supply HELP :(
Good evening, can someone help to create a simple design having this conditons:
The design should include the following components:
-Diode (linear, zener, etc)
-Transistor (bjt, jfet etc)
Additional requirements:
- input voltage is between 12V - 16V.
- output voltage should be between 3V to 6V.
- an LED must lit when the dc power supply is switch on and vice versa.
PLEASEE HELP 😞
(1,777 Views)
Accepted by Glesica
Hi Glesica,
You can use this BJT-Boosted Zener Voltage Regulator as a reference. If operational amplifier is allowed, try this
Bootstrapped-Reference Voltage Regulator.
In both circuits the DC input voltage (Vdc) can be increased to 14 V. You can keep the value of the ripple voltage (Vripple) or you may change it to, let's say,  1.5 V. This way the total input voltage falls within 12 to 16 V.
The output voltage is ≈ 5 V for both circuits.
To satisfy the remaining "additional requirement"
add an LED in series with a 1 kΩ resistor and connect it across the input voltage (top of Vripple and ground). The value of the resistor and the size of LED depend on the desired brightness.
The Zener diode and BJT in both circuits are generic components, just find the corresponding real parts.
These circuits demonstrate how voltage can be regulated, primarily, using Zener diode and BJT. To be able to focus on the roles of Zener diode and BJT in regulation, the circuits don't have capacitors. This is not a problem because the input voltage and the load are both simple. For real-world applications, input and output capacitors should be installed.
Finally, as both circuits were created to be simple like your stipulation. No overload/short-circuit protection is included in the design. Thus, use it for low-current applications and avoid employing it in circuits where overloading is more likely to occur.
G. Goodwin
(1,732 Views)
Accepted by Glesica
Omg, thank you for replying. Its a big help. 😄
(1,720 Views)
