05-14-2019 12:26 PM
Hi everyone,
I think d_chip model is a very powerfull feature of multisim, but I have a lot of problems using it.
Last one is an error displayed when I start a simulation with a component using d_chip model :
Here is the code of the model :
.model MTest d_chip(behaviour= " +/inputs A0 A1 A2 A3 +/outputs D0 D1 D2 D3 +/module M +/inputs I3 I2 I1 I0 +/outputs D3 D2 D1 D0 +/table 16 +LLLL LLLL +LLLH LLLL +LLHL LLLL +LLHH LLLL +LHLL LLLL +LHLH LLLL +LHHL LLLL +LHHH LLLL +HLLL LLLL +HLLH LLLL +HLHL LLLL +HLHH LLLL +HHLL LLLL +HHLH LLLL +HHHL LLLL +HHHH LLLL +/endmodule +/instance M A3 A2 A1 A0 D3 D2 D1 D0 +")
The aim is to create a ROM component that students can easily edit with a webtool I have created. It will generate the code of the model. But, currently, I have this error message while I write the code manually on Multisim (v11). On the v14, no error is displayed, but the component does nothing.
I don't understand. So, if you have any idea, your help will be appreciated.
Thank you by advance.
PS : NI, It will be very helpfull to have more detailed errors from the d_chip parser.
Charles
Solved! Go to Solution.
05-16-2019 01:34 AM
Solved problem !
Using /table directly in the d_chip behaviour seems to work only for models with one output.
It seems when we use a d_chip model with several outputs, it is necessary to use /module to define the behaviour of each output.
In so doing, no more error and the component gives good outputs states.
