Multisim and Ultiboard
D/A converter
Hello. I am currently doing a shape filter and need a 8bits Digital to Analog Converter. (DAC) . From the library, i only managed to find current output  DAC. I want to have a DAC converter with voltage output. Any recommendations?
(4,973 Views)
Output the IDAC into an Op amp. See image below. You could also do this differentially for better performance.
Images from App Note: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwiYiuHKm9LLAhUB0mMKHV-TDm4...
I should mention, you can use other op amps, not just the ones shown. Also what version Mutisim are you using?
(4,943 Views)
Not sure what version Mutlisim you are using, but I found voltage DACS in the master lib under mixed. I also found models in my mouser lib. Not sure if my version is compatable, but I will post the schematic using a few symbols below. Note: The bottom symbol U3 can be used with simulation.
(4,936 Views)
Hi. I am using multisim version 11.0. There is another question about the IDAC from the library. What is the code table used inside it? eg. 1111111 will get what as output. I am going to use the DAC converter as bipolar operation.
(4,920 Views)
