Multisim and Ultiboard
Converting Transfer Function with Initial Outputs in Simulink to LabVIEW
I need help for converting/design a Transfer Function in Simulink called "Transfer Function with Initial Outputs" into LabVIEW. It has an option to set Initial input and Initial Output that the normal transfer function in LabVIEW does not have. Really appriciate if someone could help me in this.
Ridhwan Ali
(3,680 Views)
Is there anyone that could help me in this matter?
(3,652 Views)
Hi tebu,
There is no tool that will allow you to directly translate a Simulink function into LabVIEW. You may be able to recreate the functionality in LabVIEW if you know the internal workings of the function, however, a direct translation is not possible. I apologize for the inconvenience.
Aaron P
http://www.ni.com/support
(3,634 Views)
