Recently, I use the DEC_BCD_10_INV component in Multisim to serve as a decoder in my circuit design. When I simulate the circuit in Multisim, the behaviors are as expected. However, when I export the PLD design into the Basys 3 FPGA board, strange things happen. The decoder does not work as expected. Instead, it works as follows:
4-bit binary number The port which is in high voltage
0000 O0
0001 O3
0010 O4
0011 O5
0100 O2
0101 O1
0110 O8
0111 O7
1000 O6
1001 O9
Then I find that the problem may lie in the pin assignment of this decoder since the attribute of this component shows following information. The order of O0~O9 corresponds to the above strange results. However, I still don't know the exact reason behind it. Is there any reasonable interpretation regarding to this decoder?
