Multisim and Ultiboard
Components not in multisim libraries
Hi!
I'm an italian high school teacher.
I'm newbie to MultiSim.
I'd like to simulate a PWM interface that use, among others, this two componenents that are'nt in the MS embedded libraries:
  • STMicroelectronics STP10NK60ZFP
  • Optoisolatore uscita transistor 4N35X
I'd like to know wich is the better and faster way to solve the issue:
  1. search and find an equivalent component in the MultiSim library
  2. use a spice model available on the productor's website (if there is one)
I've tried the second way for the mosfet following this tutorial: http://www.ni.com/tutorial/3173/en/
But at step 6 I've received this error message:
I must specify that I'm a mechanical engineer and I teach System and Automation with limited electronic competencies.
Is there anyone that can help me?
Thanks in advance
(3,956 Views)
searching for your error message I found two forum threads that could give you useful insight:
In the meantime I'll ask NI Multisim experts for advice about the most convenient way to simulate components not present in Multisim embedded libraries.
Alessia
(3,917 Views)
Hi. Alessia.
This is a very important issue for me.
Thanks in advance
(3,908 Views)
it seems you made a mistake in one of the first steps in the Component Wizard; you defined a symbol to use on the schematics having 3 pins (component symbol pins), but the SPICE code defines 5 inputs/outputs (model pins). That does not match up. I'd guess you picked a symbol with only three pins in step 3 of the wizard.
If you can't figure it out, could you please attach the component file? Otherwise I'm afraid I can't help you that much.
Alessia
(3,903 Views)
Hi alamanna, thansk for your reply.
I've downloaded the model directly from the ST website:
https://www.st.com/content/st_com/en/search.html#q=STP10NK60ZFP-t=resources-page=1
Attached to this mail the downloaded model.
Otherwise, if I look on the ST website, I can see that the component has only 3 pins:
Any idea?
Thanks in advance,
(3,879 Views)
Hello mforbiz,
I had a look at the SPICE model you attached and the SPICE code itself also defines three parameters/pins (named 1, 2, and 3 in the .SUBCKT definition), so that's fine:
* MODELLING FOR STP10NK60ZFP
.SUBCKT STP10NK60ZFP 1 2 3
LG 2 4  7.5n
I tried the steps of importing the model into Multisim myself...
and found the cause: The comment in the first line confuses Multisim. Remove it and it works:
Comment removed.Comment removed.Successfully proceeded to next step.Successfully proceeded to next step.
Edit: I am using Multisim 14.1.0. I did some further testing and found the issue being correlated to the comment containing the model name.
This is fine:
* This is a comment
.SUBCKT testik 1 2
R 1 2 2K
.ENDS testik
This errs out:
* This is testikabcd a comment
.SUBCKT testik 1 2
R 1 2 2K
.ENDS testik
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(3,849 Views)
