01-09-2012 04:31 PM
I have recently purchased and activated a student version of Multisim 11.0.2, I am trying to create a circuit and there is no component toolbar present amongst others. All the relevent boxes appear to be checked via view- toolbars, so the tool bar ought to be present but is not.
Solved! Go to Solution.
01-10-2012 09:55 AM
Hi RGP,
Thank you for your post. The usual fix for this is to change the Global Restrictions within Multisim.
To do this please follow the instructions in this KnowledgeBase Article: http://digital.ni.com/public.nsf/allkb/609A763289E6E81D8625739F0052151F
Please let me know if this fixes it.
Best Regards,
01-10-2012 03:10 PM
Hello Benjamin,
Thankyou for your pointers, followed the link a did as prompted. However, under the general tab none of the boxes where checked. Clicked OK anyway but it appears to be just the same.
Any other suggestions? Should I try un-installing and re-install?
Many thanks,
RGP
01-13-2012 03:17 AM
Hi RGP,
It may be that your user interface configuration is corrupt. To set the user interface to the default configuration please follow this knowledgebase article.
http://digital.ni.com/public.nsf/allkb/2719D00E36A4D53A8625721300685B3F?OpenDocument
Please let me know if you are still having problems.
Best Regards,
01-14-2012 08:31 AM
Hello Benjamin,
This does not appear to work either. Please see the attached file for a picture of what I'm getting. Under the New User Configuration file tab I have run through the various options, to no avail.
Many thanks,
Robert.
01-17-2012 08:35 AM
Hi Robert,
Thanks for your reply.
If possible I would now recommend uninstalling multisim,it could be a corruption of multisim itself. Also after uninstalling please delete the C:\Program Files\National Instruments\Circuit Design Suite 11.0 folder. Then restart the PC and re-install.
01-17-2012 06:06 PM
Good evening Benjamin,
Prior to your previous post I had already un/ re-installed the software to no avail however, I did not delete any files. So, although I could not find the specific file you mentioned in your post I did find a couple folders in the 'c' drive marked NI which have been deleted.
Following another un/ re-installation and despite a couple error messages occurring saying the ''installation has failed' (please see the attached word file, should these be a concern?) and lastly, sorting out the 'Global Restrictions' with Rodney, Multisim toolbars work!
I would like to say a big thank you for persevering with me.
Best wishes,
Robert.
