Multisim and Ultiboard
Compiler results: 21 - Errors, 11 - Warnings
#include<htc.h>
#define port P1
#define dataport P2
#define key P0
#define sec 100
sbit rs = port^0;
sbit rw = port^1;
sbit en = port^2;
sbit col1=key^4;
sbit col2=key^5;
sbit col3=key^6;
sbit row1=key^0;
sbit row2=key^1;
sbit row3=key^2;
sbit row4=key^3;
sbit lock_output=P0^7;
int check=0;
int digit[4]={0,0,0,0};
int dig_input[4]={0,0,0,0};
int dig_input_recheck[4]={0,0,0,0};
int i,k;
void delay(unsigned int msec) // Time delay function
int i,j ;
for(i=0;i<msec;i++)
for(j=0;j<1275;j++);
void lcd_cmd(unsigned char item) // Function to send command to LCD
dataport = item;
rs= 0;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcd_data(unsigned char item) // Function to send data to LCD
dataport = item;
rs= 1;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcd_data_string(unsigned char *str) // Function to send data to string
int i=0;
while(str[i]!='\0')
lcd_data(str[i]);
i++;
//delay(10);
return;
void lcd(unsigned char str[10])
lcd_cmd(0x38);
lcd_cmd(0x0e);
lcd_data_string(str);
void ans()
if(check>3)
lcd_cmd(0x01);
lcd_cmd(0x82);
lcd_data_string(" LOCK OPEN");
lock_output=1;
delay(300);
while(1);
else
lcd_cmd(0x01);
lcd_cmd(0x82);
lcd_data_string(" WRONG PASSWORD");
lock_output=0;
delay(300);
void code_check() // Function to check password
if(i<=3 )
switch((i+1))
case 1: {
if(dig_input[0]==digit[0])
check=check+1;
break;
case 2: {
if(dig_input[1]==digit[1])
check=check+1;
break;
case 3: {
if(dig_input[2]==digit[2])
check=check+1;
break;
case 4: {
if(dig_input[3]==digit[3])
check=check+1;
break;
delay(10);
if(i==3)
ans();
void display(int a) //Display function
switch(a)
case 1:{
lcd_data('*');
delay(100);
digit[i]=1;
code_check();
break;
case 2:{
lcd_data('*');
delay(100);
digit[i]=2;
code_check();
break;
case 3:{
lcd_data('*');
delay(100);
digit[i]=3;
code_check();
break;
case 4:{
lcd_data('*');
delay(100);
digit[i]=4;
code_check();
break;
case 5:{
lcd_data('*');
delay(100);
digit[i]=5;
code_check();
break;
case 6:{
lcd_data('*');
delay(100);
digit[i]=6;
code_check();
break;
case 7:{
lcd_data('*');
delay(100);
digit[i]=7;
code_check();
break;
case 8:{
lcd_data('*');
delay(100);
digit[i]=8;
code_check();
break;
case 9:{
lcd_data('*');
delay(100);
digit[i]=9;
code_check();
break;
case 0:{
lcd_data('*');
delay(100);
digit[i]=0;
code_check();
break;
void check_col1()
row1=row2=row3=row4=1;
row1=0;
if(col1==0)
display(1);
row1=1;
row2=0;
if(col1==0)
display(4);
row2=1;
row3=0;
if(col1==0)
display(7);
row3=1;
row4=0;
if(col1==0)
row4=1;
void check_col2()
row1=0;
if(col2==0)
display(2);
row1=1;
row2=0;
if(col2==0)
display(5);
row2=1;
row3=0;
if(col2==0)
display(8);
row3=1;
row4=0;
if(col2==0)
display(0);
row4=1;
void check_col3()
row1=0;
if(col3==0)
display(3);
row1=1;
row2=0;
if(col3==0)
display(6);
row2=1;
row3=0;
if(col3==0)
display(9);
row3=1;
row4=0;
if(col3==0)
row4=1;
void check_password_col1()
row1=0;
if(col1==0)
dig_input[k]=1;
row1=1;
row2=0;
if(col1==0)
dig_input[k]=4;
row2=1;
row3=0;
if(col1==0)
dig_input[k]=7;
row3=1;
row4=0;
if(col1==0)
row4=1;
void check_password_col2()
row1=0;
if(col2==0)
dig_input[k]=2;
row1=1;
row2=0;
if(col2==0)
dig_input[k]=5;
row2=1;
row3=0;
if(col2==0)
dig_input[k]=8;
row3=1;
row4=0;
if(col2==0)
dig_input[k]=0;
row4=1;
void check_password_col3()
row1=0;
if(col3==0)
dig_input[k]=3;
row1=1;
row2=0;
if(col3==0)
dig_input[k]=6;
row2=1;
row3=0;
if(col3==0)
dig_input[k]=9;
row3=1;
row4=0;
if(col3==0)
row4=1;
void pass_set()
row1=row2=row3=row4=0;
while(col1==1 && col2==1 && col3==1);
for(i=0;i<4;i++)
k=i;
delay(50);
lcd_cmd(0xc4+i);
delay(100);
if(col1==0)
check_password_col1();
else
if(col2==0)
check_password_col2();
else
if(col3==0)
check_password_col3();
lcd_data('*');
delay(50);
void main()
int e,j=0,count=1;
col1=col2=col3=1;
//FOR PASSWoRD INPUT
do
lcd_cmd(0x01); //Clear LCD screen
lcd_cmd(0x81);
lcd("ENTER PASSWORD:");
pass_set();
for(e=0;e<4;e++)
dig_input_recheck[e]=dig_input[e];
lcd_cmd(0x01);
lcd("CONFIRM PASSWORD:");
pass_set();
for(e=0;e<4;e++)
if(dig_input_recheck[e]==dig_input[e])
j++;
if(j<4)
lcd_cmd(0x01);
lcd_cmd(0x85);
lcd("PASSWORD");
lcd_cmd(0xC2);
lcd("NOT MATCH");
delay(300);
while(j<4);
while(count<4) //Code input and check
lcd_cmd(0x01);
lock_output=0;
lcd_cmd(0x82);
lcd("ENTER PASSWORD");
check=0;
for(i=0;i<4;i++)
delay(100);
lcd_cmd(0xc4+i);
if(col1==0)
check_col1();
else
if(col2==0)
check_col2();
else
if(col3==0)
check_col3();
count++;
delay(1);
if(count==4)
lcd_cmd(0x01);
lcd_cmd(0x86);
lcd("SORRY");
lcd_cmd(0xc1);
lcd("NO MORE TRIALS");
while(1);
Message 1 of 1
(1,667 Views)
