05-01-2018 01:23 PM
Good evening
I have copied the schematic in attachment from a site but I'm not able to make it work.
Could you help me, please?
Tks
Solved! Go to Solution.
05-02-2018 11:31 AM
I've found the answer. I had to set to redue the time step
Tks
08-24-2018 07:34 AM
I tried your file, I can't get it started, can you explain exactly what you changed? I've tried TSTEP and adjusted initial conditions, but never started. I think it may help others out if you could explain a bit more.
08-24-2018 07:41 AM
As I played with it more, I found that if you set the "intial conditions" under the "interactive" settings from "Determine Automatically" to "Set to Zero" the oscillator starts right away.
Hopefully this will help others.
03-04-2019 08:28 PM
This helped me. Thank you for coming back and telling us what worked for you. You saved me hours of headaches
