Multisim and Ultiboard
Co-Simulation Multisim / LabVIEW
Hi all,
I'm a beginner at MyRIO and labview.
I would like to see the MyRIO analog input signal in multisim tektronix. How to simulate myrio signals in multisim? Or I want to synchronize multisim and labview simulations. My priority is to simulate multisim. I want directly work with myrio and multisim.
(2,768 Views)
Why not don't works?
Multisim Ver. : 14.2
Labview Ver. : 2015
(2,735 Views)
You should upload the actual labview code.  If that were available I would try to work with it.
(2,680 Views)
Code attached.
(2,638 Views)
I don't have a myRIO available at the  moment and I can't save my multisim file as a ms13 file.
The only change I made in the multisim file was to change the square generator frequency from 1Hz to 100Hz
For the labview VI I removed the myRIO channel and then changed the timing settings
Timing SettingTiming Setting
Lab view file saved as LV2014 is attached.
I think your issues were around the timing settings, hope this helps.
(2,609 Views)
Hi Dave,
I can't open your VI. I am trying your settings and basic circuit. This circuit works on multisim. But not works on Labview.
I can find "Control and simulation" for myrio project template. And I can't find "Control and simulation" for blank project template. Could it be about that?
(2,572 Views)
What version of LabView are you using?
I grabbed the two links below from some tutorial notes I've set aside. I recomend you try these if you haven't been through them already.
On the bottom of the second link there is another link to design a DC motor drive in Co-Simulation
Introductory Tutorial Video: Power Electronics Co-Simulation with NI Multisim and LabVIEW
http://www.ni.com/white-paper/14316/en/
Introduction to Digital and Analog Co-simulation Between NI LabVIEW and NI Multisim
http://www.ni.com/white-paper/13663/en/
(2,558 Views)
